Home > Technical (L322) > 2002-2006 diff locker front or rear
Razoric2010
United Kingdom 2004 Range Rover HSE Td6 Barolo Black
Hello all I'm new to this site, I have traveled the internet to find if there is anything I can do to put diff lockers in my rr 2004 td6 IV spoken to ARB who said they need 150 people willing to buy them before they will do it so I'm guessing g that's off the cards ..... So is there any diff from a disco or anything g else X5 what will do the trick??
Thanks all
Post #448382 19th Aug 2017 3:33pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Why would you need these on a FFRR? This car will go anywhere and further than most people can imagine as it is! If you're getting into lockers etc, then you want to do some serious things and should maybe have bought a defender!
Welcome by the way! Curious to know why you were looking into these? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #448385 19th Aug 2017 4:26pm
Razoric2010
Mostly becuase no one really done it !!! But I plan to make it into a real expedition wagon as it's bloody comfy so long journeys would be awsome and well they are capable but if they were perfect offload like defenders lr wouldn't have given them a rear e locker in the newer rr's my view is I want them for incase I need them as I'm doing an England to Asia trip as some point in the feature, so far it's got plans for custom bumpers and rock sliders under tray and half expedition half flat roof rack plus roll protection.
Post #448386 19th Aug 2017 4:38pm
stu
You are going to be busy aren't you! Look forward to seeing your beast when it's done! Don't forget the roof tent!.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #448397 19th Aug 2017 6:59pm
fisha
Not just easier fitting the locking diff from a supercharged in the rear?
As for the front ... no idea. But as said above, in the past where lockers did the job cause there was no traction control, more modern traction control systems such as the L322's can get you a long way towards that effect without the need for a locker. V8 or else ...
Post #448404 19th Aug 2017 7:41pm
RRPhil
Quaife do kits for the E53
https://shop.quaife.co.uk/quaife-bmw-limit...front-diff
Phil
Post #448410 19th Aug 2017 9:16pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Razorric. I really wouldn't bother. Spend the money on an IID tool and a decent set of offroad biased tyres. I've seen the following fatty in action and it didn't struggle at all as the TC cuts in, locks the spinning wheel and off you go.
http://www.fullfatrr.com/forum/topic24082.html GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #448415 19th Aug 2017 10:20pm
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
When driving in deep snow I was not impressed the performance of TC. It activates only when one wheel has already lost traction. Evil or Very Mad I compared the difference with my -99 P38 before and after ATB diffs in both axles and difference was notable. TC had hardly any work to do after those were installed. Wouldn't hesitate a minute to have ATB diffs in my L322. Only if I could find them. Confused -08 3.6 Vogue
-87 951
Post #460634 12th Dec 2017 8:56pm
mjdronfield
I thought the centre one locked on its own if it needed to.....
Imagine you could fit a diff from one with electronic locking rear diff but might need to check and have coded to the car or like tell it it’s there. Imagine it has a control module?
As to proper after market manual lockers I have no idea. Must be possible though....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #460639 12th Dec 2017 9:27pm
miggit
I believe that the TD6 had different ratio axles to the rest of the L322 range... So that wouldn't be as straight forward as it sounds... Yesterday I couldn't spell Engineer... Today I are one!
Post #460665 12th Dec 2017 11:41pm
I would imagine if you fitted a diff locker, this would confuse the hell out of the TC system! Maybe even causing damage?
Surely you would need a module of some sort to tell the car not to fight against itself?
Post #460669 13th Dec 2017 12:23am
Pawl
It shouldn't get confused. There would be just be a lot more traction, so the the TC would not sense wheel spin so often & therefore have less work to do.
Many Disco 2 owners fit centre diff locks ( including me) for a similar, but not so big, benefit because LR had decided Electronic TC was enough & had deleted the centre diff lock they'd previously fitted to the Disco 1. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #460671 13th Dec 2017 12:42am
p38arover
Australia
Yep.
Reduction ratio:
⇒Td6 Model 4.10:1
⇒V8 Model 3.73:1 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #460682 13th Dec 2017 7:38am
loudog3114
United States
Old thread but what can the IID Tool do to improve off-road traction? I have an '11 I am trying to build into my wheeling rig. Already have an xlifter and 32ish KO2s but I came here looking for locker solutions.
Post #706657 12th Dec 2024 1:46am
