Home > Technical (L322) > Oil Leak - Further Info please. |
MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25 |
The o rings fail and let oil weep through- the leak will only get worse the longer you leave it. The o rings are only about 30p each x 2 and the repair takes around half a hour. |
14th Aug 2017 12:26pm |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 |
Hi,
14th Aug 2017 12:31pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
OK, Thanks both. Yes, LR have quoted me £848 to repair the leak - 5 x hours labour. If they have to remove the gearbox, will they have to change the gearbox oil in it?
14th Aug 2017 12:39pm |
MRx4 Member Since: 22 Oct 2016 Location: Madrid Posts: 52 |
I found this, after five days parked
14th Aug 2017 2:16pm |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 |
Not sure which engine you have there. It looks to me like ZF6 transmission fluid, which will probably be the O rings on the electrical sleeve.
14th Aug 2017 5:32pm |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
In garage talk the "rear main" is the seal at the rear of the crankshaft where it comes out the back of the engine. On some engines it's just a round seal that's removed and a new one knocked in, on others it's a sump off job and the rear mains cap removed.
14th Aug 2017 5:39pm |
Thanks rodp. So I'll need to make sure that if the crankshaft is worn, it's done at the same time as the seal? Useful advice.
14th Aug 2017 5:49pm |
They'll lose some fluid but not all. |
14th Aug 2017 6:08pm |
Then they think it may be the same case?
14th Aug 2017 8:55pm |
Nope, the ZF6 on the 4.2 jag engine uses Lifeguard6 which is clear/straw coloured. If the patch develops over days it's almost certainly the sleeve... |
15th Aug 2017 5:50pm |
Well, tomorrow to the head doctor.
15th Aug 2017 10:04pm |
24th Aug 2017 9:20pm |
Guesses?
25th Aug 2017 6:37pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8619 |
I would go with 1 on that list.
25th Aug 2017 8:37pm |
