Home > In Car Electronics (L322) > Dice Media Bridge and Ipad Mini 2 Install - 2003 L322 4.4 V8
b348xyx
Hi all,
Thought would share my current car setup, i am sure some will like it and other won't but i am very happy with everyday use.
Basically i had a Dice Media Bridge 1500 installed few years back now which replace's the CD Changer which mainly uses on the BMWs but of course the 2003 range rover uses same system. the Dice Media Bridge has USB Port which can go straight to an ipod or iphone which means you can control music or answer the phone with the build in steering wheel controls. also has AUX in and bluetooth.
So after using an old ipod mini for many years and recently using apple music on my iPhone thought would recycle my old Ipad Mini 2 for the car and give bigger screen and alot more uses in the car.
Ipad all setup with bits i need and setup so when driving it connects to my iphones hotspot means i can listen to anything from apple music, listen to radio with perfect audio so on and use ipad for bigger screen navigation then my iphone.
Done little video to show it in use below.
Any questions let me know.
Uploaded in 4k but will take some time to process on youtube.
 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #446138 29th Jul 2017 5:11pm
