Home > Technical (L405) > Restricted Performance
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Just had this warning message come on the dash whilst poodling along on the M25 around 70 mph, followed by no power. Also heard a brief strange whooshing noise from the drivers side of the engine.
Limped home, checked under the bonnet, nothing obvious, although pressing the start button didnt stop the car for about 5 seconds.
Set alarm, unset, got in, started up, same message displayed, able to rev higher this time, but terrible whooshing sort of noise from the offside engine constantly and also with the bonnet open the front vent in the top of the wing by the washer bottle seemed to be sucking in air like a hoover!
Anybody got any ideas please??
Thanks
Neil
2013 SDV8 53k
Post #445944 27th Jul 2017 6:18pm
peanutbob
United Kingdom 2018 Range Rover Vogue SE SDV8 Santorini Black
Sounds like the turbo hose has come off. Same happened to me on a RRS after it had been in for a recall which involved replacing the hose. The garage hadn't tightened up the hose sufficiently so it was pushed off under acceleration hence the whooshing sound and restricted performance.
Post #445957 27th Jul 2017 8:00pm
Baltic Blue
The 4 short rubber hoses have been modified since 2013 because the originals are prone to splitting.
The replacement hoses are much tougher.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #445959 27th Jul 2017 8:08pm
Neil183
Thanks Peanutbob, ill try and locate it, although looking at the engine bay there doesnt seem a lot you can get at very easily...
Post #445960 27th Jul 2017 8:08pm
Neil183
Problem solved thankfully, it was the turbo boost pipe that had come off or blown off.
Phew...
Post #446008 28th Jul 2017 11:58am
Fat Wolfie
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
This is why I love these specialist forums, the simple answer is out there and an expensive trip to dealer has been averted!
I'd not have had a clue where to start if it'd been my car!
Post #446039 28th Jul 2017 4:05pm
caymanblack
Has the car got the latest part as Baltic Blue,s post?
Post #446052 28th Jul 2017 6:49pm
Neil183
Yes it seems to have, why, do you think that was a recall?
The one that came off was low down between the offside inner wing. Those 4 hoses are on the top of the engine.
Hope this helps.
Post #446081 28th Jul 2017 10:19pm
