Home > Technical (L322) > Font knocking/clunking over bumps. L322 TD6
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
Hi guys,
When driving over bumps i notice a heavy clunk coming from what i believe is the front left.
Any idea what it could be? It seems to be when the suspension extends, e.g. dropping down off curbs and so on.
Many thanks
Post #445665 25th Jul 2017 8:42am
Start with your ARB drop links.
Might be a good idea to do the MOT thing with a big pry bar on all the suspension components to see if there is any movement
Also just worth a check that everything is tight, nothing loose either on the suspension or inside the engine bay .
Post #445673 25th Jul 2017 9:46am
phillips321
Ok the the ARB drop links are a little loose where they connect to the ARB. How tight do these need to be? Is it a case of just tightening them up or worth replacing the whole bar and bushes? Any idea on parts numbers and where I can source a pair?
Thanks
Post #445785 26th Jul 2017 8:06am
miggit
Parts for the L322 are readily available, there are a lot of specialists who provide some excellent savings over mainstream parts providers....
Advanced Factors are a site sponsor, also there is Dan at Duckworth Parts for gen LR spares at better than dealer prices... he has his own section in the main menu !!
But if the anti roll bar bushes have worn you'll be in a bit of a pickle cos as far as I know LR don't sell the bushes alone, you have to buy the whole anti roll bar Sad ..... However, there are some vendors that sell the bushes separately... try here http://www.island-4x4.co.uk/suspension-par..._2837.html
Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Inventor of the 'Guide-o-Matic automatic wheel alignment tool'
Former long term L322 owner, Up/Down graded to a Classic Tractor!
Post #445805 26th Jul 2017 10:48am
phillips321
there my lack of mechanic knowledge causing trouble. The bits that are warn are the rubbers on the end of the drop links. I've just googled and it seems the come connected to the bar for less than £25 a pair. Might as well just replace the whole piece for that price. Here's to hoping it fixes the knocking!
Thanks for the help guys
Post #445807 26th Jul 2017 10:53am
phillips321
Now i'm going to ask, is it better to have jacked the car up to do this or have it on the floor?
Post #445812 26th Jul 2017 11:03am
miggit
As with all suspension jobs it's better to tighten up with it under load...ie, all 4 wheels supporting the car.... this however isn't the most practical way of changing the drop links, I usually try to jack the wheel as close to the wheel.... sometimes this isn't easy and it is better to lift the car an place an axle stand under, remove the wheel and then jack up the suspension so that it just lifts the car off the axle stand, but only by a millimeter!! just incase!
That way the suspension is sitting at it's resting height Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #445820 26th Jul 2017 11:49am
When the car is on a flat level surface the drop links aren't under tension or compression so can just be unbolted with the wheels on the ground.
Done it twice, and it's not a really bad job, just a bit of lying on the floor. Be careful not to damage the rubbers on the new ones and you will need a spanner with a thin Head on it to get purchase on the spindle to do them up from memory. There is nothing that can't be fixed with a hammer😜😜
Post #445850 26th Jul 2017 3:49pm
Most have had trouble with third party drop links. May be better to go with LR parts from dan@duckworths. .
Post #445854 26th Jul 2017 4:29pm
The LR ones are Lemforder Thumbs Up at least the ones I got from Dan were a while back. There is nothing that can't be fixed with a hammer😜😜
Post #445860 26th Jul 2017 4:45pm
miggit
Whistle Don't forget that the washer is a spacer.... otherwise you'll be doing the same job again in the near future Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #445918 27th Jul 2017 10:15am
