![]() | Home > Maintenance & Mods (L322) > 10-12 doorcard trims |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
you will need to find a way to create some weakness in the new door card at the top as on pre 2007 vehicles the side impact airbag is attached to the door behind the door card above the arm rest, where as on post 2007 vehicles this was moved and built into the side of the front seats.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Ok cheer matt - any idea re the trim strips can't find them anywhere I'd even be happy with a 3D print |
When you say trim do you mean the speaker cover or below the arm rest where the wood insert goes?
Hi matt
You will have to keep an eye out on eBay, they come up every now and then.
Aren't all the speakers and things in a different place?
Bass speakers are in the same place, mids are in a slightly different place but same mounting, airbags already been mentioned.
TBH I have baby seats in the back so I should really disable those airbags anyway is there a proper way of doing it? Or just unplugging and leaving the light on? That's would sort half the problem... Current stable:
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Just came across the thread. The rear doors don't have airbags built into them like the fronts.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16333 ![]() ![]() ![]() |
The airbags are only in the front doors... |
