![]() | Home > Technical (L322) > Font knocking/clunking over bumps. L322 TD6 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Start with your ARB drop links.
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 ![]() ![]() ![]() |
Ok the the ARB drop links are a little loose where they connect to the ARB. How tight do these need to be? Is it a case of just tightening them up or worth replacing the whole bar and bushes? Any idea on parts numbers and where I can source a pair?
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Parts for the L322 are readily available, there are a lot of specialists who provide some excellent savings over mainstream parts providers....
there my lack of mechanic knowledge causing trouble. The bits that are warn are the rubbers on the end of the drop links. I've just googled and it seems the come connected to the bar for less than £25 a pair. Might as well just replace the whole piece for that price. Here's to hoping it fixes the knocking!
Now i'm going to ask, is it better to have jacked the car up to do this or have it on the floor? |
As with all suspension jobs it's better to tighten up with it under load...ie, all 4 wheels supporting the car.... this however isn't the most practical way of changing the drop links, I usually try to jack the wheel as close to the wheel.... sometimes this isn't easy and it is better to lift the car an place an axle stand under, remove the wheel and then jack up the suspension so that it just lifts the car off the axle stand, but only by a millimeter!! just incase!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
When the car is on a flat level surface the drop links aren't under tension or compression so can just be unbolted with the wheels on the ground.
Most have had trouble with third party drop links. May be better to go with LR parts from dan@duckworths. .
The LR ones are Lemforder |
