Home > Maintenance & Mods (L322) > Engine management
Bigald
Engine management
Hi everybody new to this forum I have an 07 3.6 tdv8 Vogue it has started to flash up all terrain inoperative and engine management then goes into limp mode when you turn it off and restart it clears fault going to take it for a service and transfer box oil change as I have no service record and the service screen says inspection 01 2016 do you think this will help
Many thanks Alan
Post #444711 16th Jul 2017 12:06pm
rar110
It sounds electrical, possible low voltage or brake light switch. I suggest you have the battery load tested.
How many miles has it done? ______________________________
Post #444726 16th Jul 2017 8:37pm
Bigald
95000 tested battery it's holding 14 v
Post #444748 17th Jul 2017 7:15am
rar110
Not just voltage, but a load test.
The alternators in the tdv8 3.6 seem to fall over from about 60,000 miles. You are well into that territory, and show up symptoms like you have described. ______________________________
Post #444750 17th Jul 2017 7:29am
Bigald
Oh I see rar will have that tested cars going to service tomorrow as I haven't got service book so full service and transfer box fluid change
Post #444807 17th Jul 2017 4:39pm
Bigald
Found the problem been in for service asked them to check fault codes when I went to pick car up they told me the fault codes were low turbo pressure and needed new turbos but not 100% sure so I said did you check hoses and young lad said all good so when I got home took hoses off 10 minute job and right hand side hose was splittape it up with gorilla tape and no more limp home so it went from 5k+ to £4 for the hoses
Thank you everybody and rar for your help
3
Post #444928 18th Jul 2017 6:13pm
