Home > Maintenance & Mods (L322) > Transmission sump |
unsolicited Member Since: 30 May 2016 Location: London Posts: 128 |
It isn't necessary to fiddle with engine mounts and drop exhaust on FFRRs. All reasonably accessible from below. The Discos and RRSs are a different matter. |
3rd Jul 2017 6:55pm |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 |
If it's leaking from the sump / gearbox joint there's s good chance they have over tightened the bolts or not tightened them in the correct sequence , unfortunately you'll probably need to drain it to correctly seat it and tighten it , |
10th Jul 2017 3:42pm |
Just from memory , someone will soon correct me the torque is about 12Nm for the bolts and the sequence is start in the centre and rotate through alternate sides ( like a cylinder head) |
10th Jul 2017 3:46pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
Diagram on the right is the 6HP26
10th Jul 2017 4:02pm |
