![]() | Home > Technical (L322) > Wiper relay site - idiot dealer!! |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
Some pictures to help you. I got interested in this so had a look at mine (2010 TDV8).
aneurysm1 Member Since: 12 Dec 2012 Location: burnley Posts: 202 ![]() ![]() |
Thank you very much for that Steve. I'll order them tonight and give it a try. I'll let you know if it works out 🤞 |
Relay 2 (the one to the left of those two in the pic above) controls the wiper motor on/off.
I tried with the relays but no success. It still has the same random problem and not solved it. I'm wondering if it could be the wiper stalk at all?? |
Depends on the nature of the problem. More likely in my experience (not on RR, but other cars) would be the microswitch as part of the wiper motor that sends a trigger when it has reached the parked position. I expect LR would want you to replace the whole motor for the sake of a 50p microswitch. Current: 2010 Range Rover L322
I think you are probably right. It's £95 just for the diagnostics and then whatever they decide to do to fix the problem. I think I will have to bite the bullet and send it to them 😞 |
