Home > Maintenance & Mods (L322) > Transmission sump
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Transmission sump
I have a '07 with the 6 speed auto-box.
The garage have completely f****d up replacing the sump/filter and fluid and now it's leaking.
Due to that and a couple of other thigs, I won't let them near it again.
I have noticed that Britpart do a two-piece sump (in metal) and filter so it isn't necessary to drop the exhaust or undo engine mounts to change it.
Has anybody tried one of these and is there any downside?
Post #443379 3rd Jul 2017 1:17pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
It isn't necessary to fiddle with engine mounts and drop exhaust on FFRRs. All reasonably accessible from below. The Discos and RRSs are a different matter.
Post #443421 3rd Jul 2017 6:55pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
If it's leaking from the sump / gearbox joint there's s good chance they have over tightened the bolts or not tightened them in the correct sequence , unfortunately you'll probably need to drain it to correctly seat it and tighten it ,
Post #444139 10th Jul 2017 3:42pm
birchyman71
Just from memory , someone will soon correct me the torque is about 12Nm for the bolts and the sequence is start in the centre and rotate through alternate sides ( like a cylinder head)
Post #444140 10th Jul 2017 3:46pm
RRPhil
Diagram on the right is the 6HP26
Phil
Post #444144 10th Jul 2017 4:02pm
