![]() | Home > Camping, Caravanning and Holidays > Solar panel for tin tent |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Why couldn't it be removed? Current: TDV8 (3.6) RRS HSE
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
I'm guessing because of the hole that was drilled into the roof for the cable for the regulator |
Think I've got the answer to my own thread. |
I've never done a solar panel before, but I have fitted and removed a satellite system three times so same scenario really. These things are generally just stuck down. As you have established the feet could be left if need be and the panel removed.
How would sticking it down work on a floating roof like Coachman fit? The outer skin of the roof is not glued to the wood underneath on mine.
I don't quite get the floating roof reference! Current: TDV8 (3.6) RRS HSE
Stu
The outer skin is not bonded to the wood underneath, hence it floats. Putting screws through it would effectively fix it down and affect the way it is intended to work. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8737 ![]() ![]() ![]() |
Bond a plate over the holes with Sikkaflex, usually stuff is bonded to the van with either Sikkaflex or Caraseal IDL99. IDL99 is a non setting bedding mastic so more for sticking stuff which needs to be taken off, sikkaflex will stick it on and you can't get it off! There is nothing that can't be fixed with a hammer😜😜
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1552 ![]() ![]() |
I have a (claimed) 120 watt folding panel and it can just keep my second battery charged - and I suspect we have more sunlight than the UK |
It depends on the technology and quality of the panel. The cheap EBAY jobbies are not very good at all. I paid nearly 200 quid for my 80w panel with a charge controller but in good sunlight it does deliver a solid 6 amps.
In good sunlight I get 7 amps out of mine, a bit less in winter. Ron B. VK2OTC
@wogger, sorry for not getting back to you! Was busy!
Cheers Stu |
