Home > Maintenance & Mods (L405) > New Metal Rotary Shifter
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
Well thanks to Mr Jettec on this thread http://www.fullfatrr.com/forum/topic41375.html , I sourced a new metal rotary shifter from the Orient which arrived today.
As Jettec suggested, I bought through Aliexpress.com and got the one that came in a decent box with an allen key and a little tool to lift off the existing black shifter cap. I thought those showed interest on the part of the seller.
Just search 'Range Rover Gear' and it was the $76.00 one. Took a couple of weeks to get to the UK.
The black cap came off after a bit of a fight; you have to be quite controlled and forceful but it's only stuck on and it will pop off. It's quite tough.
Then it's a very easy matter of unscrewing the centre screw, lifting off the old shifter and replacing with the new. There's a keyway on the shifter and it'll only fit one way.
The cover for the new shifter is plastic but looks fine and wont get any wear so hopefully OK.
The nice box and foam insert it in came in will look after your old shifter should you ever need to change it.
Cover just sticks on with supplied double-sided tape.
Anyhoo, pictures speak a thousand words so see below.
Post #442553 24th Jun 2017 11:36am
GGDR
Looks great!
Sometimes a bit scary ordering things from the 'ali-bay"
Wondering if this will fit a L322 with Rotary Shift.... Hmmmm.
Any chance we can have a before and after?
. Cheers, Greg
Post #442555 24th Jun 2017 11:44am
Macpaul
Thanks, and I think it looks better in the flesh than in the pic.
No info on L322 compatibility I'm afraid and I put away the old one.
There must be dozens of photos of befores I would have thought, I just had the standard alloy/rubberised sort of shifter.
Post #442557 24th Jun 2017 11:49am
i prefer my 'range rover' logo one,
Post #442568 24th Jun 2017 2:15pm
Looks great ! Thumbs Up All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #442569 24th Jun 2017 2:18pm
Macpaul
Thanks. I don't know how hard-wearing it will be but it looks well-enough finished to last.
The plastic top shouldn't get any wear at all.
And each to their own Stan!
Post #442570 24th Jun 2017 2:21pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Thumbs Up Thumbs Up
Post #442577 24th Jun 2017 3:50pm
1strangerover2017
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Post #442582 24th Jun 2017 4:15pm
AMTony
Is this the one.....couldnt find a $76 one?
Post #442585 24th Jun 2017 4:24pm
GGDR
Stan is that standard on yours?
. Cheers, Greg
Post #442596 24th Jun 2017 5:59pm
tis a metal sticker sir....ebay.. ... - .- -.
Post #442597 24th Jun 2017 6:11pm
Macpaul
AM Tony, no I don't think that's quite the same. The cap is smooth in the pic you show, mine's got the same effect on the cap and on the sides of the shifter.
I did copy the URL but when I pasted it it was about 6 lines long.
Anyone know how to do a link on here?
Post #442618 24th Jun 2017 10:10pm
