Home > Maintenance & Mods (L322) > Advice on fitting brake pads
Webbie
I will check the disks as well. Interestingly no vibration or noise to speak of today after getting worse for the last two months.
Post #442798 26th Jun 2017 6:12pm
Weegie
It may well have been down to not removing the protective coating on the discs. See if the improvement continues. John
GAP iiD BT
Post #442799 26th Jun 2017 6:14pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
I wouldn't have thought not cleaning the discs would cause as much fuss!?
Let us know how it all pans out.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442810 26th Jun 2017 7:56pm
nino_nino
Webbie , do not put grease on the back of the pads . rubber sleeves on the caliper pistons do not like grease.
Post #442885 27th Jun 2017 6:05pm
Webbie
Thanks for the nod to the wise. His will be a Saturday morning job now.
Post #442977 28th Jun 2017 7:18pm
nino_nino
Webbie, have you sorted the brake problems?
Post #443845 7th Jul 2017 7:54pm
Check your rear discs and pads for excess heat after a run, (spit on the disc after a couple of mins) if it sizzles you have a finding calliper
Do same for front too. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #443848 7th Jul 2017 8:13pm
Webbie
Problem resolved:
Just to summarise fitted new front disks, pads, clips and pads about 5000 miles and three months ago. All genuine Land Rover parts. All fine to start with but after 3000 miles vibration and noise with gentle low speed breaking, getting worse as time with increasing mileage.
Stripped everything down again last weekend. Found break dust everywhere, especially between the back of the pad and the piston! All now thoroughly cleaned (again) everything seems to be fine and dandy and has been working without a problem all week. Fingers crossed it stays that way.
Thank you everyone for your support and interest.
Post #443896 8th Jul 2017 11:03am
