Home > Technical (L322) > L322 stuck tow bar.
phillips321
United Kingdom 2003 Range Rover HSE Td6 Galway Green
L322 stuck tow bar.
Hi guys,
Not sure how long the tow bar as been left in but it feels like it's rusted in now. Any tips on how i could remove it besides tying to a tree and flooring it?
Thanks in advance
Post #441908 18th Jun 2017 4:12pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi
Try heating up the holder up with a blow torch and then give the tow ball bit a tap or greater with a hammer.
Had to do this with mine first time .
Simon
Post #441912 18th Jun 2017 4:59pm
pip1977
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
A good soaking in release spray sorted mine out, had been in there for about 6 years when I got car. 2004 td6 Zambezi silver
2006 fiat scudo van
1971 1300 vw beetle
Post #441926 18th Jun 2017 6:27pm
CS
Assuming you have got the bolt out it is just a case of hitting it with a heavy hammer, they tend to be fitted dry and then bond to the armature with rust. Clean and grease the stem before refitting, it makes removal much easier next time. Only Range Rovers since 1988
Post #441927 18th Jun 2017 6:32pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
I never understand why people leave removable tow bars fitted when there is a space in the boot for them!.. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #441933 18th Jun 2017 7:38pm
....probably cos they are stuck. Mr. Green ... - .- -.
Post #441934 18th Jun 2017 7:41pm
phillips321
Just applied lots of WD40 in the hope this loosens it up.... here's to hoping.
Post #441966 19th Jun 2017 7:36am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I would try penetrating oil rather than WD40...
Post #441968 19th Jun 2017 8:12am
phillips321
Apologies but my knowledge of this i guess is a bit thin on the ground.... I thought WD40 was penetrating oil? I have GT85 as well? Or a lots of firearm gun oil like this stuff http://www.uttings.co.uk/p103759-bisley-silicone-gun-oil/
Post #441970 19th Jun 2017 8:15am
mzplcg
You need the oil to be mixed with a release agent, more a penetrating action.
XCP Pro
Plusgas
Corrosion X
Any of those, applied liberally, left for 24 hours etc will help. But you will likely still require a hammer. Something I did when I got mine (I changed from removable to farmer's hitch so I had to get the receiver out).
1. Acquire a good strong rope.
2. Find a good strong anchor point.
3. Tie rope to anchor point and towball.
4. Low range 1st, get lots of tension into the rope. Apply handbrake and PARK.
5. from underneath, ensuring you are not in the firing line, heavy lump hammer or a dead-blow hammer, hit the bar from behind.
That's how I got mine out. But, I can't over-stress the point about keeping EVERYTHING out of the way for when it does let go. Pets locked in the house, kids, etc etc. Mine made a large dent in a 60ft holly tree. If it had hit me I would be dead, no question.[/b]
Post #441972 19th Jun 2017 8:33am
berkshirelad
The clue is in the name - WD stands for Water Dispersant.
You need something like Plusgas
Post #441974 19th Jun 2017 8:50am
Rob99
+1 for PlusGas Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #442011 19th Jun 2017 5:44pm
Baltic Blue
A small container full of diesel is good to use for penetrating oil in such cases.
It penetrates very well but leaves an oily film which prevents further rusting..
Disadvantage, it will leave a dirty mark on your drive as well !! G reg 2.5VM Vogue Portofino red 1991- 1999
Post #442013 19th Jun 2017 6:08pm
stu
Rolling with laughter @stan.. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #442015 19th Jun 2017 6:14pm
supershuttle
Mine was stuck when I got it, soaked in penetrating oil battered with a sledge hammer - still wouldn't budge - so I just cut the bottom off and left it there. Geoff
Post #442120 20th Jun 2017 4:28pm
