Home > In Car Electronics (L322) > 04 td6 speaker issues
Ryan.h
So I bought the rr last weekend
The sat nav and radio is still how it should be but there is no sound through speakers , I've removed the amp and took a look I side (carefully)
No water in amp but some green corrosion on the pins , is there a way of cleaning pins? Also any other things to check?
Also is there a fuse that could have blown?
Post #441785 17th Jun 2017 2:03pm
Pixelpower
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
You're on the 405 forum Question
Post #441789 17th Jun 2017 2:59pm
moved ... - .- -.
Post #441794 17th Jun 2017 4:18pm
Is DSP showing on your Satnav screen menu or is it greyed out?
Post #441840 18th Jun 2017 6:21am
