Home > In Car Electronics (L405) > sim card
DrDill
sim card
Hi all
done over 2k in my new range rover and its magical, runs like a dream and the 4.4 engine is a little throaty but pulls like a train!
Any way, went to change the sim card and the new one wont stay in the slot, you push it in and its springy but wont stay in, any advice as to what i am doing wrong would be welcome.
Nigel
Post #441419 13th Jun 2017 1:09pm
Lutonboy
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Normally you have to push it in a little beyond the spring resistance of the slot to engage the catch, but it always struck me as being a little bit flimsy, which I noted when I inserted mine.
Post #441515 14th Jun 2017 3:22pm
DrDill
hi, yes tried that it just wont stay in
i will ring dealer
Post #441518 14th Jun 2017 3:44pm
stillrunning
United Kingdom 2018 Range Rover Autobiography SDV8 Loire Blue
I had this issue but for me it was the wrong way round
Or maybe it was the fact u had to actually buy one and fit yourself
Very Happy
Post #441531 14th Jun 2017 5:23pm
DrDill
I have tried all different ways.
Post #441534 14th Jun 2017 5:58pm
DrDill
It appears i did not try properly. Salesman came out and inserted correctly and it stayed in!
Post #441616 15th Jun 2017 6:02pm
stillrunning
Oh matron lol
Glad it's sorted
Post #441640 15th Jun 2017 8:31pm
DrDill
Well the cards now stays in. But the car cant read the sim, error says sim card removed!
I will order another sim and try that, unless anyone has any other ideas
Thanks
Post #441795 17th Jun 2017 4:31pm
1strangerover2017
I had a similar issue with inserting the card and finally went in, in my opion the wrong way around, but I think I had to do something with the setting ( think I used the small leaflet with the handbook ), also may need to swop the metal connector the other way around, try the new card first, hope this helps
Post #441825 17th Jun 2017 9:55pm
DrDill
New sim card bought and inserted. Still doesnt work. Says its reading card then says sim card not inserted.
Any one had this?
Nigel
Post #442145 20th Jun 2017 7:54pm
w8pmc
United Kingdom 2016 Range Rover Autobiography TDV6 Carpathian Grey
Had an issue getting the right size of SIM card, but once received it did work from the off. Is the feature switched on within Incontrol? Paul
MY17 TDV6 Autobiography In Carpathian Grey With Cirrus Interior
Post #442172 21st Jun 2017 7:39am
DrDill
Sim card is right size and it pushes in and stays in. From with in the incontrol system i select to turn on data and it reads sim fir about 5 minutez then says sim removed!
Post #442174 21st Jun 2017 7:52am
charlie croker mk2
Put the sim in a phone or tablet to prove it works on data . My Vodafone data only sim needed this before it worked in the car.
Post #442196 21st Jun 2017 12:38pm
DrDill
Okay thanks. Will try that later
Nigel
Post #442201 21st Jun 2017 12:44pm
DrDill
Sim card still not working. Dealer niw going to replace card reader.
Hopefully that will fix it
Post #443551 4th Jul 2017 7:28pm
