Home > Maintenance & Mods (L322) > My plastic trim refinishing
p38arover
Australia
I'll remember that trick. Thanks for that. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #456210 5th Nov 2017 10:14am
Paul thornton
I've found that foundary grey on eBay so will be ordering some soon along with a seat and steering wheel refurb kit. Interior revamp time!
Post #456514 7th Nov 2017 10:13pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
gizze wrote:
In the UK you can either use Plasticote Matte Black or Plastidip black spray.
This was a silver trim piece that I resprayed black using the Plasticote Matte Black, you can see how well it matches oem trim car makers use asit is almost a perfect match to the idrive controller....
It also goes on really easily.
Wipe the trim clean, then spray 3-4 light coats, dry with a hair dryer between coats or wait 10 minutes between each.
1 can will do loads.
gizze, how well has this lasted and di you use the Plasti-Kyte clear sealer on top of the Matt black? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #502495 23rd Jan 2019 7:53am
p38arover
Australia
I thought I'd respray mine.
I sanded the paint off and sprayed with plastic primer. Not a success. The primer bloomed and then cracked.
Thinking it might have been a humidity problem (it was a few months back in summer), I sanded them all back again and resprayed yesterday when the humidity was 68% and the temp was 18 deg C (it is winter!).
The same thing happened again. I'm not sure what to do next.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #635181 22nd Jun 2022 12:38pm
