Home > Technical (L322) > Air Bag Light! |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
There's an airbag in the door so it's probably linked, might have disturbed something when the cable was fitted.
9th Jun 2017 1:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
loads of connections behind the door card, as suggested one might be loose or not connected.. ... - .- -.
9th Jun 2017 2:18pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
The red airbag light also relates to seatbelt pretensioners. I had a loose wire under the driver seat. The IID tool picked it up. I just had to fiddle with the position of the wire and it was fixed. ______________________________
9th Jun 2017 8:41pm |
unsolicited Member Since: 30 May 2016 Location: London Posts: 124 |
And also the battery disconnect (yellow connector). I need to wiggle mine occasionally as it seems to develop a high resistance every once in a while... Must remember to take it apart properly next time the battery is disconnected. |
10th Jun 2017 6:51pm |
