Home > LPG > BRC wiring problem
Willos
England 2002 Range Rover Vogue 4.4 V8 Java Black
BRC wiring problem
e've hit a brick wall
It's a plug and drive ecu sf fly
I have wired the petrol injectors to the brc ecu but no signal is coming out the ecu for the petrol injectors to work. He connected the power to the ecu but again no signal coming out the ecu injectors for it to fire up on petrol
The ecu is fully working as we've swapped it from an x5 I have and works fine
Does the brc loom need to be connected to the obd socket for it to fire up on petrol only after wiring into the brc ecu or other connections to just fire up on Petrol
Sorry to trouble you but its stumped me
Post #440648 4th Jun 2017 8:03pm
dingg1
ask here
http://www.lpgforum.co.uk
Post #440654 4th Jun 2017 8:33pm
Willos
Unfortunately they are not taking any new registrations and the email I used to use is no longer valid Thanks for the tip but I cannot post on it
Post #440662 5th Jun 2017 4:58am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
did you get this sorted?
Post #442330 22nd Jun 2017 6:56pm
mr_spock
I have a BRC system on my 4.4, you're welcome to have a look at the install and compare. I'm coming up to Huntingdon on Saturday to look at a house, so could swing by in the afternoon if that's a help. PM me.
Post #442335 22nd Jun 2017 7:18pm
Willos
Thanks for the offer
I had an emer system put in after the confusion of the wiring loom
It runs fine but i would have prefer a BRC system
Its best not to touch if its running ok
Again thanks
Post #442421 23rd Jun 2017 12:19pm
Willos
After fitting a emer system which now runs smoothly (after the 12v signal wire was on a dodgy supply) we have found out the BRC ECU needs earthing
Hmmm
Post #484448 27th Jul 2018 12:00pm
