Home > Technical (L322) > Door locked shut.
crazyjelly
England 2004 Range Rover Vogue 4.4 V8 Java Black
Door locked shut.
Hi
I can't find the solution, I've looked for ages!!
The front passenger door, is locked shut.
The rest of the car locks and unlocks. But front passenger does Censored all.
How on earth do I open it!!!!!!!!!!
I've tried going in the back via the gromit. The action moves up and down but won't open.
I've tried taking off the top of the door card but can't as the doors closed.
Has anyone got any ideas on how to open it.
Ta
2004 4.4 vogue
Post #440629 4th Jun 2017 2:30pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Unfortunately I've only heard reports of having to wreck the door card if the doors locked and stuck.
Hopefully someone will have a simple solution for you but be prepared for the worst pal. Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #440671 5th Jun 2017 8:04am
does it open with the key? ... - .- -.
Post #440673 5th Jun 2017 8:14am
Rosco
I had exactly the same issue a couple of years ago, eventually had to put it into an indy. Was all fixed when I collected it, when asked how they opened it, I was met with, 'You dont want to know'...... There are crowbar marks down the inside of the pillar so I guess that was it, cant help with a cost as it was done as part of a lot of other things. Not much help but would be interested to see if you find a way of doing it as I thought the gromit method was the solution Thumbs Up
STAN.. I love your optimism Rolling with laughter
Post #440680 5th Jun 2017 8:53am
TerryT-J
Wales 2005 Range Rover Vogue Td6 Java Black
I had this problem on my front passenger door as well. It was a wiring problem which an indy garage fixed for me. They removed the lower front wing panel below the side vent, the side vent itself and the rubber plug/socket at the A pillar. Water or moisture had got in to it and corroded one of the pins to dust. They replaced this pin and cleaned up the rest of the contacts and all the door electrics sprang into life. It also cured the non functioning passenger mirror (adjustment and power fold) and the odd one of old being able to operate the passenger window from the passenger switch. Hope this may help.
Post #440696 5th Jun 2017 11:53am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Today the same Problem, so look at the picture, after repair with a new cable part, full function!
 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #468331 12th Feb 2018 9:29pm
