![]() | Home > Technical (L322) > Cooling System Nightmare |
Trickytdv8 Member Since: 03 Jun 2017 Location: Rossendale Posts: 1 ![]() ![]() |
Hello I am new to this site, After a few weeks of looking around on different site's for my problem and coming up with nothing, I have had to become a member for some experienced wise words!! The car in question in a Range Rover Sport Tdv8 2008 with 128000 miles on the clock. I have owned the car for around 19 month now and all has been running well and really enjoying the car.....
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Hi,
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
It sounds as though there is still air trapped in the system. Have you tried topping-up the bottle as the level drops? |
goopta Member Since: 04 Jul 2014 Location: Aberdeenshire Posts: 14 ![]() ![]() |
I had coolant loss and could smell it. Turned out to be one of the two metal pipes on the right hand side of the engine which are bolted to the inner wing. A right pig to get out but eventually did and it had been rubbing on the inner wing and made a small hole in it. I used plastic metal to fix it and haven't had an issue since. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Hope you can sort it out. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
he won't be back here John, anyways i've edited his post a bit for you.. |
Much better, Stan. |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Same problem here... going next week to check it. Meanwhile, bucket in the car to top it out each drive
