Home > In Car Electronics (L322) > L322 TD6 HSE 2003 Battery Drain - Fuse 12 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Well, that is what the handbook says fuse 12 is for.
29th May 2017 12:12am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Do you have a rear fan blower? If so there is also the equivalent of the front fsr controlling it. Does your rear fan speed rise and lower in speed if you turn the control knob. If not I would be inclined to think about the fear fan fsr.
29th May 2017 10:04am |
phillips321 Member Since: 05 Nov 2016 Location: Countryside Posts: 50 |
So I tried to trace the fault but fuse 12 is connected to sooooo much kit I really don't know where to start. The rear blower power adjuster is a bit temperamental as it feels it's either full on, or off.... maybe that is the FSR that needs looking at?
29th May 2017 6:24pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
great idea to relay fuse 12 temp measure to keep the fatty working as it should without to much work (until you get the time to do the work) |
29th May 2017 9:06pm |
The rear fan fsr is mounted next to the fan itself under the centre console. |
30th May 2017 12:51pm |
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 34 |
I've got a battery drain and fuse 12 is at least partly responsible. Did you solve your problem with fuse 12? All the best
12th Aug 2024 1:13pm |
V8Simon Member Since: 18 Dec 2019 Location: North Wales Posts: 20 |
On my prev RR, an 03 TD6, the battery drain was caused by one of the front headlight washers. I'd have to look back through my comments on here but fuse 12 rings a bell. 2004 Vogue SE TD6
2nd Sep 2024 3:56pm |
