Home > Technical (L322) > Deployable Side Steps
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
Does anyone have any info on removing them in order to change a tyre, I have an allen key but only instructions how to fit and nothing on removing so the car can be jacked up...sure I read something but can't find it now..Thanks
Its a 2012 Westminster 4.4 If that is needed.... I need more help than most...sorry !!
Post #439546 25th May 2017 12:22pm
r1chardh
United Kingdom 2012 Range Rover Autobiography TDV8 Stornoway Grey
Here's the page in the Deployable Side Step manual, hope this helps.
(ETA) and a link to a hi-res: https://www.dropbox.com/s/sj4bluv5bq2xhuf/image1.JPG?dl=0
Post #439554 25th May 2017 1:51pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
At least you have the allen key, mine doesn't.
I did ask in another thread if anyone had attempted jacking with the bottle jack when the steps were deployed but not removed?
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #439557 25th May 2017 2:06pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I jack up mine with the merc sprinter bottle jack and the steps deployed but not removed. The jack handle fits fine between the step and the wheel. No probs as long as you leave a door open or use the procedure (which I can never remember) to lock out the steps. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #439590 25th May 2017 5:24pm
ianmacd
Thanks Nomad.
Post #439641 25th May 2017 11:06pm
muppet
Many Thanks for the info and especially Richard for the picture, greatly appreciated......I assume I need to remove the actual step as in the image....
Ian do you want me to send you the size of the key in case you need one ? I need more help than most...sorry !!
Post #439645 26th May 2017 5:58am
mzplcg
I would advise investing the the Sprinter bottle jack, or a trolley jack. You are pretty much guaranteed the steps won't remove as the diagram shows, it will be raining, the Mother-in-Law looking on in scorn etc etc. Far better to have a way of jacking without removing the step.
Post #439648 26th May 2017 6:40am
