Home > General > Build Spec - Options
Martynh
Hello!
I'm currently searching for a nice 2010 facelift TDV8 and was wandering if there is an easy way to see the build spec of prospective cars? Obviously everyone specs them differently and often the adverts on auto trader etc are generic and miss important options when the car was built.
I'm used to BMWs and you can find the spec from the registration plate via a vin decoder website.
Thanks in advance
Martyn
Post #440625 4th Jun 2017 3:09pm
you can put the vin into https://www.vindecoderz.com/ but you'll have to physically see the car to get the vin.. ... - .- -.
Post #440630 4th Jun 2017 3:34pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Try the LR plate in the warranty site you are using for BMW's. If it's the site I use, it'll do Land Rovers as well and will give you the VIN. Put the VIN into the site that Stan linked and you're good to go 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #440633 4th Jun 2017 3:57pm
Martynh
Just tried it, works perfectly. Thank you!
Post #440637 4th Jun 2017 4:23pm
