![]() | Home > General > L322 reliability |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
you mostly read of repairs and maintenance issues because people don't post when things are running smooth |
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
I bought a 2004 petrol with 125,000 miles two and a half years ago.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
The trick is to spend a little, often. Prevention is way cheaper than cure in most instances. At the end of the day, they were expensive cars, they cannot be run on fiesta money sadly. |
sheep911uk Member Since: 09 May 2017 Location: Northampton Posts: 30 ![]() ![]() |
Thanks for all the replys, I do very little mileage only work 4 miles from home so probably do less than 500 miles a month. |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
Ask if the timing guides have been replaced, from my research they can go as early as 90k miles or last almost twice that. It is a £2k to £3k job if you cannot do it yourself.
Sorry I forgot to say I was looking at a TD6 diesel. |
For your miles anticipated go for a petrol , diesel won't be hardly warned up after a 4 mile journey and the 4.4 petrol is a much better buy than a 6 pot oil burner |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
I agree, there would be no real advantage to a diesel over that distance.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
the problem is you are dealing with a 14 year old car or thereabouts.
Yeah, £100 is only the same as an extra tank full of diesel |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
I agree with all that's been said. I was advised to go for a 2007 onward, and 'touch wood' have had no major issues. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
As has been said you would be better going for a petrol. As an idea I have a 2007 which I have had for 4 years and have covered 80k in that 80k apart from normal servicing I have had a new gearbox under warranty at 95k no cost to me also heated cooled seat failed £400 front airbag burst needed both fronts done and new pump £1800 new aircon pump £800
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
with all due respect there is no way you wouldn't have an issue with that model. L322 vary widely in reliability.
Thanks Cliff, I realise there are good and bad cars however all I see is the negative stuff, I guess people don't post when they have no issues. |
