![]() | Home > Technical (L322) > Front pdc |
I get my valet to press the button on the centre console |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
real drivers dont need PDC |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Get a winch then you'll never use front pdc's again |
Have it switched on when you set your personal memory settings at the side of your chair , failing that maybe your PDC settings are set incorrectly , just a matter of using one of the sub menus on the touch screen to put these right ..... |
Can of worms mate this will now be an endles thread on touch screen sub-menus |
dark.soul999 Member Since: 04 Feb 2009 Location: Bucuresti Posts: 9 ![]() ![]() |
Hi Paul !
ill be serious now ok on mine it only engages the pdc when i put it into Reverse ore back into Drive if im lucky lol. other than that i manually switch on . onto no6 Range Rover
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
Speedymarktd6, this is how it works on mine. But on the D3 the pdc (front and rear) came on automatically if the vehicle speed dropped to about 5mph. I just wondered if it could be set to come on by default at this speed? |
The mode of function differs from RR to D3 ! On new D3 (MY09?) that mode it’s same as RR. |
Paul j, I think you've got it |
wardpg Member Since: 26 Jul 2008 Location: Preston Posts: 76 ![]() ![]() ![]() |
My 2004 MY D3 also had auto front PDC but it was altered in Disco about 2 Model years ago. The reason given was that people were complaining that in traffic jams the pdc was alarming all the time and had to be switched off, didnt bother me as I thought that it was the better system . Only problem is that since getting the FFRR SWMBOforgets to switch it on when forward parking and has had some near misses ah well whats a few marks on the front bumper!!! |
