Home > Technical (L322) > Electric Windows and side mirrors not responding
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks,
Was out earlier and went through the drive way at McDonalds and found that the electric windows won't work. Tried all other windows but no response either. Noticed that the side mirrors don't respond either.
I have a seen few threads about a similar issue but they refer to issues only limited to the drivers door. There are also references to the door wiring look and connector which I will check in the morning. In the meantime, anyone experienced the similar issue on a 2010 Vogue?
my first issue week into the ownership so no longer a virgin anymore.. lol
Post #439093 21st May 2017 12:31am
GGDR
How about the basics: Fuse? Cheers, Greg
Post #439102 21st May 2017 8:25am
scotcruz
Good idea.. however on reading most posts the fuses were ok.. But will look at that too.. any idea where the fuse is?
Post #439113 21st May 2017 10:29am
GGDR
pop onto https://topix.landrover.jlrext.com - you'll need your VIN and the Owners Manual is there.
There is a fuse box in the boot, one in the rear or the glovebox and one in the engine bay. Cheers, Greg
Post #439116 21st May 2017 10:40am
GGDR
Did you buy private or dealer?
If dealer, you can just get the them to sort... Cheers, Greg
Post #439118 21st May 2017 10:41am
scotcruz
cheers mate.. Will have a look.. Bought it from a dealer but it's down south in Liverpool
Post #439123 21st May 2017 11:05am
scotcruz
UPDATE
Turns out to be gremlins lol.. went out to check and thought I will check the windows. Started it and the windows work as ecpected.
Spooky but I'm happy all is good.. cheers for the input guys
Post #439134 21st May 2017 12:52pm
