![]() | Home > In Car Electronics (L405) > Dash cam what and where |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
this is one of many threads re this, it relates to the L322 but the info can be adapted to yours,
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
I have a Blackvue Dashcam fitted to the L322 which was hardwired as part of a purchase deal so no unsightly wires
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1457 ![]() ![]() |
The latest Blackvue ones do now have wifi so you don't have to remove the SD card to download recordings. 2021 D350 Fifty Edition - Carpathian Grey
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 ![]() ![]() ![]() |
I am torn on these, I have read quite a few threads where there has been an accident and if the police are called they confiscate everyone's dash cams....I know the theory that if you have done no wrong then you have nowt to worry about but what if you had been over the speed limit but some numpty caused a fatal accident and you ended up also having the finger pointed and your own equipment buried you?
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 ![]() ![]() ![]() |
Would it not help you in that situation and prove that your speed wasn't the cause of the accident? The camera doesn't lie so if you were "buried" with the cameras evidence then surely you would be to blame ? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
I keep a spare micro SD card to hand |
Why not just loose the sd card (they are small enough to get lost very easily) a full functioning camera with card but no footage has got to look worse than one that you didn't know needed a card |
My card has old recordings on it, so I would assume that there was an issue with the camera overwriting the SD card.
Hopefully it would help Easy to say but when the person you might be up against has a £1000 per hr lawyer who knows how things can be twisted, I would just rather be in control of what evidence I chose to provide. If I was in the wrong, in part or in full would I also want my evidence to be the thing that got me done? Morally if I am to blame then I should be done but we also make mistakes. |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Fair point, didn't think of that! 2010 defender utility
Be ok if you can swap out the sim and decide when and if you want to submit the sim, wonder if the courts would not normally want to self incriminate or would they just take any opportunity?
'' if she had been stopped with a dash cam ''
The higher end ones seem to have gps as a bonus, thinking about it gps is only really useful to prove you were within the limit or how close you were if someone else was at a huge speed differential.
They wouldn't need GPS to figure out speed, could be very easily calculated using time and distance traveled. I guess if everybody is speeding round and killing people then a dashcam isn't for you.... |
