Home > Maintenance & Mods (L322) > Wakey wakey when it comes to starting
Diddley
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
My partner has been using the FF lately and she said when pressing the start button nothing happens. She is new to driving and sits there thinking have I done something wrong. Then about eight to ten seconds later the truck fired up.
I have noticed this also when using this weekend.
Can anyone shed any light on this?
Truck is a 4.4 tdv8
Post #437003 3rd May 2017 9:22pm
It's probably upset being called a TRUCK Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #437005 3rd May 2017 9:30pm
GGDR
^ Laughing
Is she pressing the brake? Cheers, Greg
Post #437006 3rd May 2017 9:32pm
Diddley
Pressing down on pedal 👍
Calling it a truck is habit from past double cab pickups.
Post #437012 4th May 2017 5:45am
pressing the start button momentarily won't start it if the engine is cold...press for about 3/4 seconds works.. ... - .- -.
Post #437015 4th May 2017 6:24am
Mr Tee
I've found that sometimes even with footbrake pressure , the car still says press the brake to start. One of those annoying "foibles" of JLR ownership. Also if you whack it straight into drive immediately after starting , it will often shut down again.
Post #437018 4th May 2017 7:58am
Mikey
There is/was a software update for that, Steve Thumbs Up
Post #437021 4th May 2017 8:29am
Mr Tee
Oh aye, how much?? Whistle
Post #437031 4th May 2017 9:26am
CS
I'd say a short delay is normal, the diesel glow plugs are warming up before the engine is turned over. But 8 to 10 secs sounds longer than I get, even on cold mornings, so maybe a diagnostic check helpful? Only Range Rovers since 1988
Post #437156 5th May 2017 11:41am
dpm
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Diddley, did you resolve this problem as mine does this also. Or anyone have any idea why it happens.
Post #478927 19th May 2018 11:44pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
its a mysterious gremlin with no explanation. a 10 minute battery reset always does the trick for me.. I've started carrying a 10mm spanner with me Smile Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #478928 20th May 2018 1:32am
^ Fitting a battery isolator switch is easier than continually undoing a battery terminal. Wink Thumbs Up
Post #478931 20th May 2018 6:34am
TomCobbly
Mikey how do I tell if I have had the software update? Do you have to rely on the main dealers to get it done? 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #479019 21st May 2018 8:53am
dpm
So is there an update or fix for this as it is really annoying
Post #479724 30th May 2018 6:59pm
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
It maybe due to the system waiting for the glow plugs to warm the engine. What doesn't kill you is just bidding it's time.
Post #479855 1st Jun 2018 8:39am
