Home > In Car Electronics (L322) > Rear Lighter Socket
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Rear Lighter Socket
Morning all,
Previous owner has done the mod to convert the rear lighter socket to ignition live as per the wiki
http://www.fullfatrr.com/forum/topic32623.html
But it seems like he's wired it to the green/yellow wire coming out of the small black socket with the white pivot locking arm on it on the left of the picture.
Recently the rear lighter has stopped working, have checked the new relay and it appears that no power is coming from the green/yellow wire with or without the ignition on.
All fuses in the boot fuse board space are good.
So my questions are:-
1. Is this fed from another fuse somewhere, if so which one?
2. If this ignition live is now no longer live what is it meant to be feeding originally that is now not working?
Thought I might as well ask the group first before I have to start ripping any more of the car apart.
Thanks in advance. Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #436316 29th Apr 2017 8:20am
The green/yellow wire is the ignition feed used to switch the relay contacts. This wire is fed from fuse 2 of the front passenger side fuse board. From what you describe I would have expected this fuse to have blown for some reason, it's rated at 2A.
Post #436324 29th Apr 2017 9:33am
DannyH
Unfortunately fuse 2 is fine and it's a 5amp. Dan
2002 Zambezi Silver
Post #436326 29th Apr 2017 9:48am
Sorry, 5A you're right.
This is the wiring diagram that relates to the green/yellow wire albeit with the error that transposes the green/yellow with red/yellow.
Post #436328 29th Apr 2017 10:06am
DannyH
Hang on so is the wire feeding in to the fuse board via the black plug or feeding out of the fuse board via the black plug? If it's feeding in to the board then I think the wire might have failed where the other guys has soldered into it that's all I can think of at the moment. Will finish washing the car and do some more investigating. Dan
2002 Zambezi Silver
Post #436334 29th Apr 2017 10:27am
p38arover
Australia
Deleted - misread thread Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #436340 29th Apr 2017 11:50am
Weegie
Would be worth re-doing as it may have a dry joint from the previous soldering. John
GAP iiD BT
Post #436341 29th Apr 2017 12:09pm
DannyH
Nope no power going to the main plug that the green wire connects into behind the light cluster. Any other fuses relating to this one? Very strange how it's randomly stopped working yet I've not noticed anything else not working Dan
2002 Zambezi Silver
Post #436344 29th Apr 2017 12:42pm
DannyH
Well I think I need to get my coat. Seems everything works fine when the ignition is fully on so I'm just stupid and assumed the first click of the key would be enough to power everything up like in my previous cars. Sorry for wasting everyone's time. <bows> Dan
2002 Zambezi Silver
Post #436358 29th Apr 2017 2:50pm
It happens Thumbs Up Very Happy
Post #436372 29th Apr 2017 5:28pm
