Home > Technical (L322) > Yellow engine check light?
Emperor Mong
I had the yellow engine check light come on today. Checked fluid levels - nothing wrong. Anything else I can do to clear it or is it a trip to the dealer.
Post #44346 3rd Jan 2011 6:10pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Crap fuel is the usual suspect......or something more sinister. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #44349 3rd Jan 2011 6:20pm
dan_uk_1984
A check engine light suggests a problem with your engine management system, often relating to the emission side of things.
Levels of fluids won't effect this.
You should get it to a dealer as a matter of urgency as if you are over-fuelling you will destroy your cats (there are 4 so get expensive to replace) and if you are under-fuelling you can burn your valves.
To avoid spurious warnings the fault has to generally occur 3 times before you get the light, so don't be thinking its just a one off. For future it may be worth getting yourself a USB OBDII code reader, this will allow you to read the code and re-set it after you've fixed the problem
Post #44360 3rd Jan 2011 6:29pm
Lambda Oxygen Sensors are a common culprit but your car is quite new for CAT damage....
Could be a loose sensor though hit by a lump of ice....
Post #44361 3rd Jan 2011 6:30pm
Emperor Mong
Safe to drive to the dealer? It came on when I was about 5 miles from home (steady not flashing). Dealer is about 8 miles away.
Post #44398 3rd Jan 2011 8:24pm
daveo
where about are you...i have a hand help unit.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #44401 3rd Jan 2011 8:32pm
If engine running as normal I would say yes.
Post #44402 3rd Jan 2011 8:32pm
Emperor Mong
Very kind offer. I am near Cambridge.
The car is running perfectly. I only noticed it on the dash. The only thing I have noticed is that it takes a fraction - and I mean a fraction - longer to start. I put it down to the battery not being at full charge (lots of heated seats heated screen, heated mirror action recently).
Post #44405 3rd Jan 2011 8:36pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
keep an eye on your temp gauge just in case.
chances are its just a faulty sensor. 2004 black Vogue TD6
Post #44426 3rd Jan 2011 10:50pm
daveo
if you were closer to london i could of checke it and see what code came up, i ran low on petrol once just about rolled into the station, spluttering and my engine light came one. but after a day it went off, the next my scanner turned up..but no codes stored.. V8 facelift Range Rover Autobiography 22" wheels.
Post #44429 3rd Jan 2011 11:07pm
Emperor Mong
Nothing drastic. Some fault that required new software to be downloaded. £100 and an hour of my time.
Could be much more expensive than that as I test drove a 4.4TDV8 when I was there. Me want.
Post #44511 4th Jan 2011 5:14pm
daveo
did you ask what software was upgraded, i find it hard to believe just because there is a software update for said module and that they want to charge you for it, why should your car need it..
please find out what and why... V8 facelift Range Rover Autobiography 22" wheels.
Post #44526 4th Jan 2011 5:56pm
dan_uk_1984
I can perform this software upgrade on your car for a mere £75. I wont tell you what it does or anything about it. You'll just have to believe I've done it - and in reality all I've done is clear the fault code.
I smell Bullshit!
Post #44551 4th Jan 2011 6:57pm
Emperor Mong
I am not sure of all the details. IIRC, the fault code was that one of the cylinder banks was running hotter than the other, showing a petrol mix fault. There was a service bulletin that recommended a software upgrade for the ECU that would prevent the fault from reoccurring. I took that to mean that the cylinder bank wasn't hotter, merely that the ECU had gotten confused and that a software update prevents this from happening again.
Have I been fleeced by a main dealer?
Post #44553 4th Jan 2011 7:04pm
letsavit2
have you got the fault code, is it on the invoice? if so google it. 2004 black Vogue TD6
Post #44571 4th Jan 2011 8:30pm
