Home > Maintenance & Mods (L405) > changing parking sensor
Jon S
My range rover occasionally tells me that parking aid is unavailable so I must go to my dealer (only happens now and again when reversing). I suspect I just have a dodgy parking sensor so thought I'd see if I can track it down and replace it. Does anyone know how to tell which one is faulty and do I need to remove the rear bumper to get to them?
Thanks
Jon
Post #436237 28th Apr 2017 2:06pm
can you fill in your car profile so we know what car/year/model you have... ... - .- -.
Post #436238 28th Apr 2017 2:15pm
Jon S
sorry about that- I have filled out the profile but perhaps it isn't showing for some reason- it's a 2013 SDV8 vogue SE.
Post #436239 28th Apr 2017 2:23pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I don't know about the newer ones but on the older L322's you can hear the sensor clicking when it's working if you put your ear to it outside.
Post #436242 28th Apr 2017 2:38pm
There is a software update for the rear parking sensors - i had the same problem. All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #436246 28th Apr 2017 2:50pm
Jon S
thanks angel - I'll see if my local dealer knows about this (it's out of warranty but they should do this sort of thing as a courtesy surely??)
Post #436252 28th Apr 2017 3:08pm
Jon S
Hamlet-I think the 405 and 322 have the same sensors so I'll listen for a clicking- just to check they click WHEN they are working rather than when they aren't?
Post #436256 28th Apr 2017 3:14pm
hamlet
Yes, you should hear a clicking when it's actually working if you put your ear to the sensor in the bumper, make sure it's switched on inside, as in, you should hear the beeping in the cabin when you're outside with your ear to the bumper.
Post #436257 28th Apr 2017 3:17pm
Jon S
thanks hamlet- that's clear. I've just phoned my local dealer who tells me that there are "no outstanding updates" for my vehicle so they would have to put it on their diagnostic equipment which is a minimum charge of £118+vat (so £140)!! before they've done anything to fix it!!
I'm going to listen for some clicks first (ie run my own diagnostic test)
Jon
Post #436262 28th Apr 2017 3:33pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
If it's out of warranty you may find it cheaper to use a LR specialist rather than a dealer. Good luck
Post #436263 28th Apr 2017 4:10pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Isn't there a website to tell you if there's outstanding recalls / updates for your vin number ? £140 may be a good enough incentive for some dealers to tell porkies.
Post #436277 28th Apr 2017 6:23pm
WOW *nice* dealer - NOT ! Evil or Very Mad All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #436313 29th Apr 2017 7:28am
Jon S
While looking for solutions,I found this http://www.landroverproblems.com/tsbs/Range_Rover/2014/
Which kind of gives some details into some possible faults but I think it's American (so maybe restricted value in UK) and it doesn't tell me what to do about things. May be of use to some though.
Jon
Post #436317 29th Apr 2017 8:28am
