Home > In Car Electronics (L405) > Dash cam what and where
Page 1 of 3 123>
bear100
I am thinking of getting a dash cam fitted to the 405,
Has anyone on here done so? What did you fit and how did you run the cables?
Halfords have an offer on at the moment so may be a good time to purchase! 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #437096 4th May 2017 8:50pm
this is one of many threads re this, it relates to the L322 but the info can be adapted to yours,
http://www.fullfatrr.com/forum/topic23389.html?highlight=dashcam ... - .- -.
Post #437100 4th May 2017 8:59pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
I have a Blackvue Dashcam fitted to the L322 which was hardwired as part of a purchase deal so no unsightly wires
The installer was a bit peeved when he found out what the installation element was compared to what he was getting so I presume that a decent auto electrician could do you a good deal independantly of the purchase
The only issue I have is that the dashcam records to a micro SD card which is a pain to extract and view from - if there was an option of downloading by Bluetooth or uploading to a Cloud happy days 2009 Stornoway Grey Vogue TDV8
Post #437106 4th May 2017 9:34pm
Rob99
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
The latest Blackvue ones do now have wifi so you don't have to remove the SD card to download recordings. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #437107 4th May 2017 9:44pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
I am torn on these, I have read quite a few threads where there has been an accident and if the police are called they confiscate everyone's dash cams....I know the theory that if you have done no wrong then you have nowt to worry about but what if you had been over the speed limit but some numpty caused a fatal accident and you ended up also having the finger pointed and your own equipment buried you?
Equally there are too many scum bags who cause accidents on purpose or claim no fault when it clearly is their fault...then I would want the camera on my side.
Any thoughts as the self incrimination side of things?
Post #437724 9th May 2017 7:09pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Would it not help you in that situation and prove that your speed wasn't the cause of the accident? The camera doesn't lie so if you were "buried" with the cameras evidence then surely you would be to blame ?
Post #437727 9th May 2017 7:17pm
I keep a spare micro SD card to hand Whistle
TBH I'm not sure I could swap it quickly enough if pulled over, but after a bump with time to wait, I could get it swapped.
Post #437734 9th May 2017 7:29pm
Freddie The Fish
Why not just loose the sd card (they are small enough to get lost very easily) a full functioning camera with card but no footage has got to look worse than one that you didn't know needed a card Whistle
I guess you have to hope that you are able to remove it (not maimed or dead) and that no one else has one.
Post #437743 9th May 2017 7:46pm
My card has old recordings on it, so I would assume that there was an issue with the camera overwriting the SD card.
You're actually supposed to format the cards on a regular basis to avoid such an issue as it does happen.
The only disadvantage would be no opportunity to re-introduce the evidence if it turned out to be in your favour.
There was also a thread on here a while ago about a camera that was confiscated and the Police wouldn't return it for ages - even though it proved the person was clearly not at fault and his insurance company were about to settle to his disadvantage Shocked They wouldn't even provide him a copy of his own footage Rolling Eyes
Link here
Post #437746 9th May 2017 7:53pm
Caddyshack
Hopefully it would help
Easy to say but when the person you might be up against has a £1000 per hr lawyer who knows how things can be twisted, I would just rather be in control of what evidence I chose to provide.
If I was in the wrong, in part or in full would I also want my evidence to be the thing that got me done? Morally if I am to blame then I should be done but we also make mistakes.
Post #437750 9th May 2017 7:58pm
bear100
Fair point, didn't think of that! 2010 defender utility
1994 discovery 1
1975 bobtail (gone)
Post #437758 9th May 2017 8:10pm
Caddyshack
Be ok if you can swap out the sim and decide when and if you want to submit the sim, wonder if the courts would not normally want to self incriminate or would they just take any opportunity?
I was talking to ex met policeman on holiday, his wife had been taken to court for doing over 100mph, on advice she admitted to 94mph and got a big fine (over £1k) and a long ban, if she had been stopped with a dash cam would that have helped enforce an over 100? (Not arguing, just do not know the answer)...funny thing was that the day after the ban she got a fine for having previously driven in a bus lane come through the post and he went mad....next day nother bus lane FINE arrived.
Post #437761 9th May 2017 8:15pm
'' if she had been stopped with a dash cam ''
not every dashcam has a gps module so no speed will be recorded... ... - .- -.
Post #437764 9th May 2017 8:20pm
Caddyshack
The higher end ones seem to have gps as a bonus, thinking about it gps is only really useful to prove you were within the limit or how close you were if someone else was at a huge speed differential.
I notice one allowed you to format to blank from an iPad but obviously it would need to be in the unit, in signal and powered up.
Maybe the benefits outweigh the small potential down sides? And if worried disable or don't have GPS speed recording?
Post #437769 9th May 2017 8:39pm
Freddie The Fish
They wouldn't need GPS to figure out speed, could be very easily calculated using time and distance traveled. I guess if everybody is speeding round and killing people then a dashcam isn't for you....
Post #437774 9th May 2017 9:11pm
Page 1 of 3 123>
