Home > Maintenance & Mods (L322) > Need to top up the engine oil but no funnel/filler?
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
While I was on holiday last summer I checked the engine oil and it was a little low so, having a 5litr pack of Castrol in the box in the boot I decided to top it up. Which was when I found I had left my oil filling funnel at home. Pouring oil in the strong winds of Tiree isn't easy without dribbling oil over the top of the engine cover so a quick recce of the garbage bin soon got me a 1.5litre drinks bottle - washed it out and removed the screwtop then cut the base off - heypresto a funnel as long or as short as you want it and if you retain the screwtop you can seal it again to clean up unused oil in the neck of the bottle with a rag without dripping even more oil over the engine top. The 5litre oil can's extended spout is not easy to get under the bonnet of the FFRR and also tip it to get the contents out without a major oil spill. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #44281 3rd Jan 2011 3:36am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I have a cut of pop bottle that I have been using for years. Probably lasted longer than a proper funnel, and a hell of a lot cheaper! Very Happy
Post #44282 3rd Jan 2011 6:10am
Tim in Scotland
A suitable money saver for the FFRR owner then Mr. Green 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #44283 3rd Jan 2011 7:46am
This approach is also useful for screenwash filling operations on my A4 Cab .
Post #44284 3rd Jan 2011 9:23am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Disclaimer: Don't use the same bottle for both Wink Thumbs Up
Post #44293 3rd Jan 2011 1:43pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
also throw the closed end in the shed\garage for mixing filler for when your decorating next. 2004 black Vogue TD6
Post #44296 3rd Jan 2011 2:17pm
dan_uk_1984
Use a milk bottle carton - then the funnel incorporates a handle!
Post #44317 3rd Jan 2011 3:20pm
