![]() | Home > LPG > Which BRC ecu is in your car ? |
RRR207 Member Since: 27 May 2016 Location: Basel Posts: 49 ![]() ![]() ![]() |
I have a 2005 L322 with a BRC kit ..... having not been involved at all in the fitting where would I find the info you need? Current - RRV Autobiography 4.4V8 2005
Willos Member Since: 11 Apr 2017 Location: Huntingdon Posts: 21 ![]() ![]() ![]() |
It will say fly sf or plug and play or sequent 56 on the front of it
I'll have a look when the wife brings it back later |
Thanks |
Where will I find the ECU? The bit pictured is what I was expecting to say the info you needed but it doesn't appear to unless I'm missing something (which is entirely possible!).
Foulolron Member Since: 05 Aug 2015 Location: East Yorkshire Posts: 29 ![]() ![]() ![]() |
My used an Emer ecu without issues - had it fitted as part of a new lpg front end (ecu / injectors / vaporiser etc) which replaced the old system (which last 170k miles) - it was a good system that offered good features for a reasonable price |
Thanks for that
Looks like most installs ecu is in the sealed box on the drivers side engine compartment
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
biggest problem with BRC kit's is the ECU's it can say FLY on the ECU however the software can be reprogrammed to DRIVE or most other BRC software
Thanks for the offer but have one already in a kit off a l322
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2230 ![]() ![]() ![]() |
I have OMVL and Zavoli injector rails... on my my I have 2x KING emus and large EMER rails... my fitter (local if you need one) was showing me the differences - if you get a king Ecu you can mix and match rails if need be but if you get say a bias Ecu you are fixed with bias gear... |
lol that was some good typos there I will leave them - I meant ECU not EMU and M6 not MY MY |
