Home > Wheels & Tyres > Diamond cutting or polishing alloys......
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Any opinions on these or am I just wasting my time and creating more work for myself?
I'm not even sure myself.
To blingey?
Any opinions on what kind of black paint I should use?
I was thinking just a few coats of high gloss enamel paint without a lacquer might do it.
Post #437065 4th May 2017 5:06pm
Caddyshack
United Kingdom 2014 Range Rover Autobiography SDV8 Indus Silver
You won't get a lacquer to adhere to that very well.
I has some Porsche design 90's mirror polished and the advice was to just seal them with a quality wax and just re polish as and when.
If you do get lacquer on there it will soon go milky and need stripping again.
I like them though.
I was told recently that you should only diamond cut a wheel 3 time before you affect the profile etc of the wheel.
Post #437068 4th May 2017 5:40pm
hamlet
Thanks for the reply.
I'm not going to lacquer the polished face of the wheels, just leave that polished, it was the other bits, the sides of the spokes I'm going to paint, they just have black tape on them now to see how they look, just wondering if I would get away with an enamel paint without lacquer as I'll be painting up to the edge of the polished surface and don't want to end up with too much of a paint/lacquer ridge where the paint ends and the polished surface begins.
Thanks again.
Post #437158 5th May 2017 12:56pm
hamlet
So finally, 5 months after picking up a set of 18" wheels, I've eventually finished polishing and painting them, and fitted them a few weeks ago.
Any opinions on the end result?
Post #451719 22nd Sep 2017 12:30pm
Mikey
They do look good, but they look a bit "lost"
Post #451721 22nd Sep 2017 12:43pm
hamlet
Thanks Mikey, I agree, I'm happy with the way they turned out but as you say, a little lost and not really filling the arch.
They don't look quite as bad in real life and the wider tyres (285's) that I fitted compensate slightly, (I have a bit of a thing for wide tyres........ Embarassed , memories of youth).
Looks better if I park it in access mode....... Very Happy
Can't really complain, I picked up the wheels including a set of part worn tyres and full set of wheel nuts for £85, just a bit of paint, sanding, polishing and time to get them like they are, I had a full set of good Hankook Ventus ST 285/55/18" tyres that I took of my Navara before it went to Nissan heaven.
No issues with driving, no real change noticed.
Post #451728 22nd Sep 2017 1:21pm
if you have an iidtool you could lower the body and then those wheels might not look so 'lost'......... ... - .- -.
Post #451745 22nd Sep 2017 3:32pm
hamlet
Stan, I think the whole thing look fabulous just as it is........... Razz
I'm just agreeing with Mikey to keep him happy....... Shocked ......... Laughing
But that's not a bad idea at all, I'll see how the whole set up grows on me as it is over the next while.
Or maybe a nice set of white wall tyres...... Idea
Having said that, if I was to be doing anything to the suspension I should be trying to fix the Censored leak...... Rolling Eyes
Post #451751 22nd Sep 2017 4:24pm
hamlet
I took you're advice and "slammed it" Stan........... Rolling with laughter
"If you want to raise the attitude you need to lower the altitude".............Aaron Haufman.
Post #452448 29th Sep 2017 1:18pm
you got a bit carried away there Ted.. Laughing ... - .- -.
Post #452455 29th Sep 2017 2:45pm
hamlet
Laughing Laughing Laughing
I depressurised the system last weekend to change the beads and filters in the compressor dryer and took the opportunity for a photo.
Post #452456 29th Sep 2017 3:21pm
