| Click image to enlarge |
Was able to find 2006 HSE with RSE at the pick and pull. Here is a pic of the middle port. Next step is to remove the connectors for the aux port. Grabbed Ricardo's pic of the non-rse connector for comparison. It would seem that the only additional wires are the three for audio in positions 6, 7 and 8. Pics also of what the connector looks like. To remove from the plug remove the red retainer and use a pick to release the plastic retainers in the center of the plug which will allow you to pull out the wire from behind as long as you have 3 hands. Will make a video that explains better.
