Home > Technical (L322) > Restricted Performance After Fuelling |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8669 |
crank or cam position sensor up the duff possibly leading to a mismatch in the readings. There is nothing that can't be fixed with a hammer😜😜
21st Mar 2017 5:37pm |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
I have given the garage the readings hopefully it's nothing too expensive! |
21st Mar 2017 6:09pm |
Update for the Garage. They think the timing chain has slipped?? Is this common/possible? I think it is the Bank 2 Cam 2 sensor. If they replace that then see if the fixes the rest of them.
24th Mar 2017 9:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35446 |
i know the 5.0 suffers with a front end rattling, maybe this is associated? ... - .- -.
24th Mar 2017 10:45am |
It has rattled since I have had but did the usual checking on forums and it seemed to cause no issues. The car hasn't missed a beat before this happened and there was no sign of it happening. I still think its a sensor and the garage aren't really sure what they are doing. |
24th Mar 2017 11:31am |
Anyone had a timing chain replaced? How much did it cost? |
24th Mar 2017 2:48pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1447 |
I would have expected some other damage if timing chain had slipped so my first thought would be camshaft sensor.
24th Mar 2017 2:51pm |
Thats what I thought but he says it is off 32 degrees |
24th Mar 2017 3:00pm |
So, After no car for a week. The specialist has had a look on their systems and it would seem something has slipped as all sensors are providing readings. Going to do a compression test to check they Cylinders are ok and then set about opening her up to have a check what has gone wrong.
3rd Apr 2017 12:56pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
I've just been quoted £1800 for chains, tensioners ect and cam cover gaskets and a couple of other seals..thought that was reasonable for the amount of work involved 👍 |
3rd Apr 2017 1:01pm |
Thanks Alistair,
3rd Apr 2017 1:27pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3186 |
My 4.4 BMW v8 petrol recently had the chain guide and chains and gaskets done at a LR indie. £3k Inc vat. |
3rd Apr 2017 5:33pm |
Cheers. Just have to hope there is no cylinder damage! |
3rd Apr 2017 6:03pm |
This may give more info
3rd Apr 2017 6:16pm |
