![]() | Home > LPG > LPG not switching over |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1361 ![]() ![]() |
ask here
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
Agreed on the solenoid valve.
Pluribus Member Since: 12 Feb 2017 Location: Yalding - Kent Posts: 16 ![]() ![]() ![]() |
Thanks, I'll post over there now. |
I've not had to do this before. How easy are they to change? Is the solenoid valve easy to access? |
I've just been out to the car and the engine management light came on. Read the fault code with Torque and it said O2 sensor heater circuit malfunction (bank 2, sensor 1).
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
There is a little filter in the pipeline under the bonnet, if that is not replaced every 20 k it might block. Bear in mind I'm a non tech. |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
did you get sorted? |
Yes I did, and I apologise for not updating this forum. I hate it when people do that!
Good to hear all is well |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
Glad you got it sorted |
