air suspension fault , fault code numbers? | |
hi guys , wondering if i could have some help yet again? ( i am learning)
my troublsome l322 is living upto its name well , air suspension currently inactive
i have no lights on the switch panel , i NOW get air suspension inactive on the dash too !
i have the lynx diagnostic system but its pretty new to me so struggling a little , i have cleared faults and the only recocurring one is " fault 53 ecu fault currently not present "
anyone know what this means? it seems locked in one position and wont self level , it happend after being parked with one wheel on an incline and has stayed that way so one front bag is 25mm lower than the rest at all times
i can make the compressor run and it runs the inflate/deflate procedure but literally nothing happens apart from the compressor runs !
the air pressure is at 11.8 bar which i believe is correct?
made the compressor run 5-6 times and it gets to 50-60 degrees so i think the compressor is ok?
live data shows the suspension figures rising and falling as they should so i think all the sensors are ok too?
REALLY STUCK !
below are the codes before i cleared them and after i cleared them
thankss
