Home > Technical (L322) > Metallic Rattly noise on hard acceleration 4.2 S/C |
Maybe the engine pinking? |
8th Mar 2017 10:50pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Could be one of the cats is breaking down internally? Current Fleet:-
9th Mar 2017 6:35am |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 302 |
No i don't think so it's not that sort of noise thankfully. And you would expect it more in higher gears. 2005 E60 M5 2006 L322 4.2 SC 2020 Tesla Model S Long Range -------- 2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe |
9th Mar 2017 7:49am |
That is where I was thinking annoyingly. 2005 E60 M5 2006 L322 4.2 SC 2020 Tesla Model S Long Range -------- 2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe |
9th Mar 2017 7:50am |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Exhaust heat shield? Bish.
10th Mar 2017 10:24pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
From your description , it sounds like the noise is only apparent when the supercharger is really doing its stuff .
22nd Apr 2017 6:48pm |
I dont think its supercharger related to be honest, mainly as it doesn't occur in higher gears. If it were S/C related it would be there in every gear at a certain RPM etc. I had to "make use" of the power plant this weekend a couple of times - dawdling tourists between Glencoe and Loch Lomand required some committed multi vehicle overtakes!
23rd Apr 2017 6:49pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
theres a few heat shields under there, in and around the transfer box as well. get under there and tap them all to see if any are loose or catching on something. Its likely to be a heat shield i would think. I had one making a bit of a buzz on mine, couple of mins under it had found it and bent it back into shape. There is nothing that can't be fixed with a hammer😜😜
23rd Apr 2017 6:56pm |
