Home > In Car Electronics (L405) > Embedded SIM Problem?
w8pmc
United Kingdom 2016 Range Rover Autobiography TDV6 Carpathian Grey
All was going well with the new car's first proper outing yesterday morning until half way into my journey when the map display changed & features stopped working (Traffic etc.).
Took me a few mins to spot that the 3G symbol had vanished. Stopped for fuel a little later & removed the Sim, cleaned it & re-inserted but it won't come back. Then thought it maybe needed a reset so when I stopped at my final destination, switched the car off for a while & then returned but still nothing. Car was left overnight but again no 3G this morning.
Checked on the My3 website that the Sim hadn't been deactivated but all appears normal so I'm stumped as to what can have happened & frustrated that the Sim actually offers up more features than I thought so now they're unavailable it's annoying.
Any ideas or anyone else had this happen. Going to request another Sim from 3 in case it for some reason just went faulty mid journey.
Post #430334 7th Mar 2017 8:14am
Baltic Blue
Put the sim in an old phone and check it works OK?
Check it has still got some credit on it if it is PAYG ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #430336 7th Mar 2017 8:45am
Lutonboy
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Is it possible you've used up your monthly data allowance? I know you said you had checked the Three website for the SIM status and probably checked then, but nonetheless thought I'd ask.
Post #430337 7th Mar 2017 9:09am
WillyT
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
Try going into the mobile settings on the cars info screen. Noticed mine turned the mobile data off for no apparent reason. Turned it back on and its been fine since then.
Post #430345 7th Mar 2017 10:54am
I have a 12Gb 12 month 3 SIM in my iPad - it stopped after a month - I tried turning stuff off & back on with no luck.
I went back to the 3 store who looked everything up & spoke to a support team, they told me to try wifi off & back on - and voila. They claimed they hadn't done anything else, but I'm not entirely convinced.....
Post #430358 7th Mar 2017 11:49am
w8pmc
Sorted.
Hadn't realised a Mobile Data settings section existed so once found i just switched it off & back on. No idea why it wasn't working as everything appeared ok under the Settings but a switch off & back on fixed it.
Also noticed Wifi in there but unsure what that would do as it was as well as Hotspot so appeared to be an ability to connect the car to any available wifi hotspots which i can't work out why that wold be needed.
Post #430409 7th Mar 2017 8:59pm
WillyT
Hotspot allows others in the vehicle to connect their iPad's, laptop's etc to the cars 3g and get internet connection.
Connect to wifi allows the car to connect to available wifi networks e.g. at home. Saves using data from the SIM
Post #430465 8th Mar 2017 3:08pm
w8pmc
Thanks. I had kind of assumed that but am at a loss why you'd park your car close enough to a wifi hotspot just to get free data? Why would you be using the cars data at home?
Just strikes me as odd as i can't see any need for the car to be connected to an external wifi source.
Post #430499 8th Mar 2017 8:09pm
WillyT
Probably for those who don't have a SIM inserted. Whilst connected to a wifi network a route can be planned, POI searched for, traffic & weather info downloaded (although won't update once enroute), and satellite images downloaded.
I presume thats the reason although there may be a other reasons.
Post #430507 8th Mar 2017 8:33pm
w8pmc
OK, that does make sense now:)
Post #430509 8th Mar 2017 8:35pm
w8pmc
Now the SIM card has stopped working again. Tried the same I did yesterday by switching mobile data off & back on but it just says reading SIM with the flashing dots in the top right corner & then displays what looks like a capital G with a line through it.
I got 3 to send out a replacement SIM card yesterday, so hoping for some reason they've killed the old one in readiness for the replacement, however they never mentioned that would happen.
Post #430523 8th Mar 2017 10:53pm
w8pmc
Great, 3 sent out the new SIM & sent the wrong size & it isn't one you can cut down so being a full sized one i'm no further forward.
That said, they did confirm that as they ordered a new SIM, this killed the old one automatically, so when the new one arrives & assuming it's now the correct size i should be back in the game. Paul
MY17 TDV6 Autobiography In Carpathian Grey With Cirrus Interior
Post #430578 9th Mar 2017 1:43pm
