Home > General (L405) > New to the forum, Can anyone help?
Funky Monkey
United Kingdom 2013 Range Rover Autobiography SDV8 Barolo Black
Hi I'm new to forum, So would like to say "Hi" to everyone, I have a 2013 Autobiography 4.4sdV8 in Barolo Black, I keep loosing coolant from the expansion tank, there are no signs of a otherwise leak and car doesn't over heat, Does anybody have any ideas or suggestions?..
Crying or Very sad
Post #430138 5th Mar 2017 7:52pm
Are you over filling it ?
How much are you losing ?
What drew your attention to it ? Not somrthing I regularly check......
Post #430144 5th Mar 2017 8:13pm
Dolphinboy
These expansion tanks have a known fault of developing a fine hair crack in one of the corners which allows a fine mist to escape which dries in the heat of the engine bay. Try replacing for a new tank.
Otherwise it may be your camcover gaskets being old and drying up.?
Post #430154 5th Mar 2017 9:02pm
Funky Monkey
Warning light comes up on dash, loosing entire tank, but it seems to be intermittent... filled it to correct level and it was fine and has been for over a week, light came on this morning,tank was empty but system seemed full, topped it up had to go to heathrow, when i got back it was empty but temp gauge was normal..!
Post #430155 5th Mar 2017 9:05pm
Funky Monkey
Hi Dolphinboy, the car is only 4yrs old!. (L405) so its a new shape,
Post #430156 5th Mar 2017 9:10pm
In my experiece, you need to lose quite a bit of coolant before it's likely to overheat
A slow leak is a Censored to find - as Dolphinboy says, it can quickly evaporate.
I hadn't realised the L05 had a coolant level warning light - that's good to know Thumbs Up
Post #430158 5th Mar 2017 9:24pm
Funky Monkey
Post #430160 5th Mar 2017 9:35pm
