Home > Technical (L322) > Faulty LCM
muddy_v8
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Faulty LCM
Hi Guys
Done my thermostats and temp bang up to the middle and lovely warm heating. Now the LCM is failing I think.
Indicators stuck on. No hazards. Then the brake lights stuck on. Took the LCM out and stuck in the airing cupboard over night. Then it worked so maybe a reset or drying it out from any possible moisture. Next time I use it no headlights no indicators. Next time all works.
Is this an indication to a faulty LCM ? Can these be repaired or can I use a second hand one. ? I understand these hold the mileage in the eprom (maybe the chip can be swapped from mine.....
Any suggestions. Thanks
Post #430120 5th Mar 2017 6:29pm
muddy_v8
No one any experience with these ?
Very hit and miss one day you have all lights next day indicators dont work rear lights do etc
If you disconnect the battery and re connect all good for another couple of drives... Big Cry
Post #430397 7th Mar 2017 7:23pm
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Did you ever get this fixed?
My Lcm has a small fault but nothing like this. Shocked
Post #439062 20th May 2017 6:24pm
Missed this first time around, but the brake light switch (under the pedal) has been known to cause similar problems (especially brake lights stuck on) .
Post #439087 20th May 2017 10:17pm
muddy_v8
Mine was moisture in the unit itself causing the problems. Now we are in "summer" it has no issues.
Post #439217 22nd May 2017 6:02am
