![]() | Home > Technical (L322) > Weird Cruise Control Problem |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
I know this is an old thread, but I have the exact same problem.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Not something silly like a loose wire and slowing down helps stop it bouncing around? Ed |
OO__OO Member Since: 15 May 2014 Location: Manchester Posts: 18 ![]() ![]() ![]() |
I had a problem with cruise control keep switching off after a few seconds, sometimes a minute or two. After some investigation I found it was a faulty (aftermarket) brake light switch. Fitted new genuine (cheaper then aftermarket! about £12) & problem solved. |
