Home > In Car Electronics (L322) > Dash cam install
alistairh
Dash cam install
https://www.transcend-info.com/Products/No-692 hi. I've picked up one of these and was planning on having it mounted just behind the rear view mirror. It has a 5v power supply and I'm wondering if it would be possible to somehow use the wiring from the rain sensor connection to power it? If so any advise would be greatly appreciated
Post #429411 27th Feb 2017 3:04pm
you can use a feed behind the interior light unit or run a feed up from the glovebox fuse array...
loads on this if you search or have a look in the wiki for the write ups.. ... - .- -.
Post #429412 27th Feb 2017 3:06pm
alistairh
Great.not as bad as I thought then. Shall have a good read up tonight Thumbs Up thanks Stan..
Post #429415 27th Feb 2017 3:15pm
