Home > In Car Electronics (L322) > A/V off ....HELP?
Weegie
Result Thumbs Up John
GAP iiD BT-Sold
Post #429450 27th Feb 2017 8:11pm
JT
England 2006 Range Rover Vogue 4.4 V8 Tonga Green
hi Jamie. had same problem a few months ago. water dripping onto module. removed it and dried it out also disconnected all fibre optic cables in that area and left a heater fan running in boot for 3 to 4 hours. put everything back and all worked. water was leaking through tail gate seal, need to order new one from Dan. in meantime have put plastic bag over all electrics to divert water into spare wheel compartment. hope this helps. cheers John
Post #429477 27th Feb 2017 9:31pm
Jamie_diver
Ireland 2005 Range Rover Vogue Td6 Java Black
Hi John,
Thanks for that, water has at some point got in and caused the problem though it is all dry in there right now, I will take your advice onboard.
cheers
J.
Post #429506 28th Feb 2017 10:11am
