![]() | Home > Off Topic > getting songs off ipod to use with my new umno interface! |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
I used some software called media widget, http://www.bootstrapdevelopment.com/ipod-to-itunes-transfer which copies iPod to pic. |
If you connect the i-crap via USB so you can see it as a mount point (linux) or a drive letter (windows) then you can copy the files directly from there. They all have hexadecimal random names though so you will need to listen to each one and then rename the file. It was a ball ache when I did mine but it did save me from buying software to do the job.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
Paul - that seems to use itunes which I am trying to avoid. But thanks 2007 Vogue TDV8 with 255/55/20's fitted |
mzplcg - that sounds a bit techy for my skill level! 2007 Vogue TDV8 with 255/55/20's fitted |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Apple doesn't want you to take song off your Nano. It's a way of trying to stop music copying. Normally, you have the songs on your computer, put them in iTunes, then use that to move them on/off the Nano (or other iDevice). People have a problem when a computer or hard drive crashes and the iDevice now has the ONLY remaining copy. ITunes won't help you here. There are programmes that will take the songs off the Nano, but it's much easier to just take them from their original location. AFAIK, iTunes WILL let you take a playlist off the Nano because that's not music, just a data file about what music the play. The playlist should work in other Apple/Mac/iDevice things, but might need converting to work somewhere else. Depending on the size of the list, conversion vs just redoing it on the new device should be considered carefully. Good luck. |
Joy - the thought of re-putting 1000 odd songs onto the pc really doesnt fill me with any pleasure! 2007 Vogue TDV8 with 255/55/20's fitted |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Which nano do you have, it may be possible to put it in disc mode, you can then access it as you would a USB drive and pull the files off it. Google iPod nano disc mode. Worth a try but doesn't work for all iPods. There is nothing that can't be fixed with a hammer😜😜
Pretty sure its a nano 5 2007 Vogue TDV8 with 255/55/20's fitted |
https://m.youtube.com/watch?v=bScPME9cdxc[/url] There is nothing that can't be fixed with a hammer😜😜
You were reading my mind northern!
Yes, you have to unhide the folders and music files. I have found in the past that the labelling of the folders can be different and comprises of just random letters, which can make it laborious, however the music is there and accessible. There is nothing that can't be fixed with a hammer😜😜
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
You could plug you iPod into your PC, install iTunes and then burn MP3 cd's @ 120 tracks per disc approx. If you go down that route, reduce the burn speed otherwise it often fails at high speed. |
Good advice above. You can get a lot of mp3s on a CD. However, the FFRR can be very fussy about the file structure. It's worth a google first if you go that route. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
^^Agree
