![]() | Home > Technical (L405) > Drive Modes & Ride Heights?? |
w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229 ![]() ![]() ![]() |
This may seem like an odd question, but i'm confident my Dealer won't give me a sensible or correct answer if asked so though i'd check on here.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
L405s and L494s don't have a lower high speed height. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
Which is a shame as the L322 lowered at motorway speeds which imo was a good thing. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
the 2002-2006 FF's did at around 65mph ..the 2006-2009 lowered at 100mph and i'm not sure if the 2009-2012 do........... ... - .- -.
MY07-12 all lower at a sustained 100 mph unless fitted with a kit such as mine to allow lowering or raising at any speed. |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I am not convinced that the auto terrain response is as effective as choosing manually based on quite a bit of off road driving. |
Thanks all.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
2017 cars can be programmed to go to access mode automatically when they are put into 'park' via the screen. Your dealer should be able to confirm, or you can google the RR brochure searching for access mode/Auto access mode, or of course just read the handbook when you get it. I was told this would be standard, so maybe one would have to programme it off if it was not wanted. I personally would prefer to avoid the extra work for the air suspension compressor etc and any risk of it lowering on to dry vegetation off road, but you or your passengers may prefer the auto lowering.
dfulgo Member Since: 16 May 2015 Location: Milan Posts: 70 ![]() ![]() |
...same on 2016... 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue) |
